*modent_reparentbymark
Reparents a single or multiple modular entities under a different parent.
*modent_reparentbymark entity_type new_parent_id mark_id ?options?
HyperMesh Tcl Modify Command
- entity_type
 - The type of modular entities to reparent. Valid value is subsystems.
 - new_parent_id
 - The ID of the new parent of the modular entities.
 - mark_id
 - The ID of the mark containing the modular entities to reparent. Valid values are 1 and 2.
 - options
 - Optional list of quoted, comma separated option strings.
Examples
To reparent “Subsystem1” under subsystem ID
        3:
    *createmark subsystems 1 "Subsystem1"
*modent_reparentbymark subsystems 3 1Errors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
2022.2
