*attributeupdatestringarray
Updates an attribute of type string array.
*attributeupdatestringarray entity type id identifier solver status behavior data length
HyperMesh Tcl Modify Command
- entity type
- The type of entity that owns the attribute.
- id
- The ID of the entity.
- identifier
- The identifier of the attribute.
- solver
- The solver number of the attribute.
- status
- The status of the attribute.
- behavior
- The behavior of the attribute.
- data
- The string array.
- length
- The string array length.
Examples
Update an attribute of type string array to [layer1, layer2] on the material with ID
7.
*createstringarray 2 "layer1" "layer2"
*attributeupdatestringarray materials 7 615 2 2 0 1 2
