*makepreservednodes
Makes the selected nodes preserved.
*makepreservednodes mark_id
HyperMesh Tcl Modify Command
This command makes the selected nodes preserved.
- mark_id
- The ID of the mark containing the nodes to preserve. Valid values are 1 and 2.
To make nodes 1-4 as preserved:
*createmark nodes 1-4
*makepreservednodes 1Errors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
13.0
