*segmentsetaddshells
Adds selected 1D and 2D elements to a segment set.
*segmentsetaddshells name mark_id reverse_normals
HyperMesh Tcl Modify Command
- name
- The name of the segment set to update.
- mark_id
- The ID of the mark containing the elements to add. Valid values are 1 and 2.
- reverse_normals
- Create segment set:
Examples
Add elements 10, 11, 12 and 13 to segment set
        "test":
    *createmark elements 1 10 11 12 13
*segmentsetaddshells "test" 1 0Errors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
2020
