*displaycollectorsbymark
Changes the display state of collectors in a mark.
*displaycollectorsbymark entity_type mark_id mode elements geometry
HyperMesh Tcl Modify Command
- entity_type
- The collector type. Valid types for this function are:
- Components
- Loadcols
- Systcols
- Vectorcols
- Multibodies
- mark_id
- The ID of the mark (1 or 2) that specifies collectors to be used in the above functions.
- mode
- The mode being performed, defined by the following:
- on - All collectors are turned on.
- all - All collectors are turned on.
- off - All collectors are turned off.
- none - All collectors are turned off.
- toggle - All collectors are toggled (visible become invisible and vice-versa).
- reverse - All collectors are toggled (visible become invisible and vice-versa).
- elements
- Indicates if elements within collectors are to be turned on or off.
- 1 - Yes
- 0 - No
- geometry
- Indicates if geometry within collectors are to be turned on or off.
- 1 - Yes
- 0 - No
To turn the elements on in the components fender, box and bolt, and keep the geometry as it
is:
*createmark comps 1 "fender" "box" "bolt"
*displaycollectorsbymark components 1 on 1 0
