*unmaskentitymark
Unmasks the entities on the specified mark.
*unmaskentitymark entity_type mark_id flag
HyperMesh Tcl Modify Command
This command unmasks the entities of entity_type that are on mark_id. Valid mark_ids are 1 and 2. Only entities in displayed collectors may be unmasked.
To unmask connectors and the realized FE, a flag of 1 must be passed. To unmask only connectors (excluding realized FE) and all other entity types, a flag of zero must be passed.
Currently supported entity_types for this command are:
- connectors
- points
- lines
- surfaces
- solids
- elements (both in components and groups)
- ellipsoids
- mbjoints
- mbplanes
- equations
- loads
- systems
- vectors
- tags
- handles
- domains
- symmetries
- morphconstraints
- comps (connectors, points, lines, surfaces, solids, elements)
- groups (main/secondary elements)
- loadcols (equations, loads)
- multibodies (ellipsoids, mbjoints, mbplanes)
- systcols (systems)
- vectorcols (vectors)
Examples
To unmask all of the displayed connectors and the realized FE:
*createmark connectors 1 displayed
*unmaskentitymark connectors 1 1
To unmask all elements in components but not elements in groups:
*createmark comps 1 all
*createmark elems 1 "by comps on mark" 1
*unmaskentitymark elems 1 0
To unmask all entities in all components:
*unmaskentitymark comps 1 0
This command does not return any errors that can be handled.
Version History
9.0
