*tableupdaterow
Updates the values in a row of a table.
*tableupdaterow name string_array number_of_strings row_index
HyperMesh Tcl Modify Command
- name
- The name of the table to update.
- string_array
- The ID of the string array that contains the row data to update. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray. This must equal the number of columns in the table.
- row_index
- The index of the row to update. Tables are indexed starting from 1 (1 to n rows).
To update row 3 of "table1" which has 7 columns with data types (integer, string, double, elements, integer, double, properties):
*createstringarray 7 1 abc 4.567 500 10 3.14159 100
*tableupdaterow table1 1 7 3Errors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
11.0
