*elementqualitydragtriaelem
Moves a tria element towards a specified point within the interactive cleanup tool.
*elementqualitydragtriaelem elem_id px py pz merge_tria end
HyperMesh Tcl Modify Command
This command, within the interactive cleanup tool, moves a tria element towards a specified point.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
- elem_id
- The tria element ID.
- px py pz
- Coordinates of a point that defines the drag direction.
- merge_tria
- 0 - Do not merge trias when they are close together.
- end
- 0 - This is an intermediate movement and there are additional movements following this one.
To drag tria element 3 towards (5.7, 3.78, 991.0) using quality criteria from a
file:
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualitydragtriaelem 3 5.7 3.78 991.0 0 1
*elementqualityshutdown 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
