*attributeupdatedoublearray
Updates an attribute of type double array.
*attributeupdatedoublearray entity type id identifier solver status behavior data length
HyperMesh Tcl Modify Command
- entity type
- The type of entity that owns the attribute.
- id
- The ID of the entity.
- identifier
- The identifier of the attribute.
- solver
- The solver number of the attribute.
- status
- The status of the attribute.
- behavior
- The behavior of the attribute.
- data
- Double array.
- length
- Double array length.
Update attribute 615 of type double array to [1,2,3,4] on the material
with ID
7:
*createdoublearray 4 1 2 3 4
*attributeupdatedoublearray materials 7 615 2 2 0 1 4
