*markmovetoincludewithcontents
Organizes entities into an include file, optionally also moving child entities.
*markmovetoincludewithcontents entity_type mark_id include_id child_entity_types
HyperMesh Tcl Modify Command
This command organizes entities into an include file.
- entity_type
- The type of entity to organize. Valid values are comps, groups, loadcols, vectorcols, systcols, beamsectcols and multibodies.
- mark_id
- The ID of the mark containing the entities to organize. Valid values are 1 and 2.
- include_id
- The ID of the include file to organize the entities into.
- child_entity_types
- The type/types of the child entities to organize. Multiple types can be specified at a time.
To move system collector systcol1 along with all of its systems into include file number 2:
*createmark systcols 1 systcol1
*markmovetoincludewithcontents systcols 1 2 "systems"
To move component comp1 along with all of its nodes and elements into include file number 2:
*createmark comps 1 comp2
*markmovetoincludewithcontents comps 1 2 "nodes elements"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0.110
