*renumbersolverid
Renumbers the solver IDs for the specified entity type.
*renumbersolverid entity_type mark_id start_id incr_val offset_val offset_flag reserved_1 reserved_2 reserved_3
HyperMesh Tcl Modify Command
This command renumbers the solver IDs for entities of entity_type contained on mark_id.
This command works in two ways depending on the entities selected. If the selected entities have solver IDs, the command will renumber the solver IDs and not the HyperMesh internal IDs. However, if the selected entities do not have solver IDs, the command will renumber the HyperMesh internal IDs (see *renumber).
- entity_type
- The type of entity selected for renumbering.
- mark_id
- The mark that contains the entities. Valid values are 1 and 2.
- start_id
- Integer value > 0 specifying the starting value.
- incr_val
- Integer value > 0 specifying the renumbering increment.
- offset_val
- Integer value to use for offsetting. Can be positive or negative as long as after renumbering all entities will have a positive ID.
- offset_flag
- Flag to specify whether to use offsetting.
- reserved_1
- Reserved for future development. Value = 0.
- reserved_2
- reserved_3
- Reserved for future development. Value = 0.0.
To renumber the solver IDs of the displayed elements starting from 100 with an increment of 1:
*createmark elems 1 displayed
*renumbersolverid elems 1 100 1 0 0 0 0 0.0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
