*hf_createdoubleattachedparams
Creates the base point for the symmetry plane, the n1/n2 node of the given line and the part of this line between n1/n2 needed for the double attached feature.
*hf_createdoubleattachedparams line_mark nodes_mark gap x_sym y_sym z_sym x_draw y_draw z_draw creation_flag
HyperMesh Tcl Modify Command
This command creates the base point for the symmetry plane, the n1/n2 node of the given line and the part of this line between n1/n2 needed for the double attached feature.
- line_mark
- The mark ID containing the single input line. Valid values are 1 and 2.
- nodes_mark
- The mark ID containing the input nodes. Valid values are 1 and 2. The node mark must contain 0, 1 or 2 nodes. If it contains 0 or 1 node it will create n1/n2 from line. If it contains 2 nodes it will try to use them, but if they are not properly chosen, it will create n1/n2 from line.
- gap
- The minimum distance between the original and reflected part.
- x_sym
- The x-coordinate of the symmetry direction.
- y_sym
- The y-coordinate of the symmetry direction.
- z_sym
- The z-coordinate of the symmetry direction.
- x_draw
- The x-coordinate of the stamping direction.
- y_draw
- The y-coordinate of the stamping direction.
- z_draw
- The z-coordinate of the stamping direction.
- creation_flag
- 0 - Create base point.
To get the base point from line 1 and nodes 100 and 101, using a gap of 0.5, a symmetry of
        1, 0,  0, and a draw direction of 0, 1,
        0:
    *createmark lines 1 1
*createmark nodes 1 100 101
*hf_createdoubleattachedparams 1 1 0.5 1 0 0 0 1 0 0Errors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
12.0
