*attributeupdatestring
Updates an attribute of type string.
*attributeupdatestring entity type id identifier solver status behavior value
HyperMesh Tcl Modify Command
- entity type
- The type of entity that owns the attribute.
- id
- The ID of the entity
- identifier
- The identifier of the attribute.
- solver
- The solver number of the attribute.
- status
- The status of the attribute.
- behavior
- The behavior of the attribute.
- value
- The value of the attribute.
Examples
Update an attribute of type string to a value of composite on an element with ID,
100.
*attributeupdatestring elements 100 1241 6 2 0 "composite"
