*attributeupdatedouble
Updates an attribute of type double.
*attributeupdatedouble entity type id identifier solver status behavior value
HyperMesh Tcl Modify Command
- entity type
- The type of entity that owns the attribute.
- id
- The ID of the entity.
- identifier
- The identifier of the attribute.
- solver
- The solver number of the attribute.
- status
- The status of the attribute.
- behavior
- The behavior of the attribute.
- value
- The value of the attribute.
Update an attribute of type double to a value of 200 on an element with
ID, 100.
*attributeupdatedouble elements 100 1241 6 2 0 200.0
