*CE_FE_UCCUpdateUseConnector
Updates a connector control using a connector.
*CE_FE_UCCUpdateUseConnector cc_name ce_id
HyperMesh Tcl Modify Command
- cc_name
- The name of the connector control to update.
- ccd_name
- The ID of the connector to use.
Comment.
Examples
Update a connector control named "my_acm" from connector 101:
*CE_FE_UCCUpdateUseConnector "my_acm" 101
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
