*CE_AddLinkEntitiesWithArrays
Update connectors at the specified locations with arrays.
*CE_AddLinkEntitiesWithArrays integer_array number_of_integers entity_type entity_mark_id entity_state ce_rules ce_le_rule tolerance_flag double_array number_of_doubles keep_existing string_array number_of_strings
HyperMesh Tcl Modify Command
This command updates connectors at the specified locations with arrays.
- integer_array
- The integer array ID that contains the connector ID and number of layers for that connector. The integer array is created using the *createarray command. This should always be set to 1.
- number_of_integers
- Integer indicating the size (number of integers) in the integer array created using *createarray.
- entity_type
- The entity type to be added to the connectors as links.
- entity_mark_id
- The mark ID the entities to use as links. Valid values are 1 and 2.
- entity_state
- The state of the link entities. Valid values are:
- ce_rules
- Flag indicating when to make the links. Valid values are:
- ce_le_rule
- Flag indicating how to make the links. Valid values are:
- tolerance_flag
- Flag indicating whether to use the default tolerance. Valid values are:
- double_array
- The double array ID that contains the add link tolerance values. The double array is created using the *createdoublearray command. This should always be set to 1.
- number_of_doubles
- Integer indicating the size (number of doubles) in the double array created using *createdoublearray.
- keep_existing
- Option for deleting existing links first then adding new links, or adding new links directly.
- string_array
- The string array ID that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
To add comps 1 and 2 to connectors 1001, 1002, and 1003 from scratch, the layer numbers for
these connectors are 2, 3, and 2, the tolerances are 10.0, 11.0, and
15.0:
*createarray 6 1001 2 1002 3 1003 2
*createdoublearray 3 10.0 11.0 15.0;
*createstringarray 4 "ce_spot_extralinknum=5" "ce_seam_extralinknum=7" "ce_spot_non_normal=1" "ce_area_non_normal=0"
*createmark comps 1 1 2
*CE_AddLinkEntitiesWithArrays 1 6 comps 1 1 1 0 1 1 3 0 1 4Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
