*CE_AddLinkEntitiesWithDetails
Update connectors at the specified locations with rules and other details.
*CE_AddLinkEntitiesWithDetails connector_mark_id entity_type entity_mark_id entity_state ce_rules ce_le_rule tolerance_flag tolerance num_ents string_array number_of_strings
HyperMesh Tcl Modify Command
This command updates connectors at the specified locations with rules and other details.
- connector_mark_id
- The ID of the mark containing the connectors to update. Valid values are 1 and 2.
- entity_type
- Type of entity to be added to the connectors as links.
- entity_mark_id
- The ID of the mark containing the entities to use as links. Valid values are 1 and 2.
- entity_state
- The state of the link entities. Valid values are:
- ce_rules
- Flag indicating when to make the links. Valid values are:
- ce_le_rule
- Flag indicating how to make the links. Valid values are:
- tolerance_flag
- Flag indicating whether to use the default tolerance. Valid values are:
- tolerance
- Used to add entities only within the given tolerance from the specified connector.
- num_ents
- Number of entities to add/update connector (connectors thickness (2T, 3T, etc.) value).
- string_array
- The ID of the string array that contains the additional input parameters. The string
array is created using the *createstringarray command. This should
always be set to 1. Valid strings are:
- ce_delete_links=1
- Delete existing connector links.
- ce_spot_extralinknum=1
- The number of extra links for spot connectors.
- ce_seam_extralinknum=0
- The number of extra links for seam connectors.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
Update links for spot connector 1 and seam connector 2 by deleting existing links
first:
*createmark connectors 1 1 2
*createmark comps 1 21 23 24 27
*createstringarray 3 "ce_delete_links=1" "ce_spot_extralinknum=1" "ce_seam_extralinknum=0"
*CE_AddLinkEntitiesWithDetails 1 comps 1 1 1 0 0 0 2 1 3Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0
