*CE_AddLinkEntitiesWithXYZs
Update connectors as group links with criteria.
*CE_AddLinkEntitiesWithXYZs connector_mark_id entity_type entity_mark_id entity_state ce_rules ce_le_rule locator xyz_array xyz_size
HyperMesh Tcl Modify Command
This command updates connectors as group links with criteria.
- connector_mark_id
- The ID of the mark containing the connectors to update. Valid values are 1 and 2..
- entity_type
- Type of entity to be added to the connectors as links.
- entity_mark_id
- The ID of the mark containing the entities to use as links. Valid values are 1 and 2..
- entity_state
- The state of the link entities. Valid values are:
- ce_rules
- Flag indicating when to make the links. Valid values are:
- ce_le_rule
- Flag indicating how to make the links. Valid values are:
- locator
- Flag that indicates how to use the XYZs. Valid values are:
- xyz_array
- The ID of the XYZ double array created using *createdoublearray command. This should always be 1.
- xyz_size
- The size of the XYZ double array. Must be a multiple of 3.
Examples
To add comps 1 and 2 as a group link to connectors 1-3, using (1.0, 2.5, 3.0) and (2.0,
3.0, 0.5) as locating coordinates. The link state is "elem", make link now, link rule is
"use ID", and the locator is to use
projection:
*createmark connectors 1 1-3
*createmark comps 1 1 2
*createdoublearray 6 1.0 2.5 3.0 2.0 3.0 0.5
*CE_AddLinkEntitiesWithXYZs 1 comps 1 1 0 1 1 1 6Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10-SA1-120
