*CE_Cleanup
Sets connectors to unrealized and back to a clean undefined state.
*CE_Cleanup mark_id
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the connectors to clean. Valid values are 1 and 2.
To clean connectors 1-10:
*createmark connectors 1 1-10
*CE_Cleanup 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
