*CE_ConnectorAreaMapMesh
Use the projections of components or elements to mesh area connectors.
*CE_ConnectorAreaMapMesh ce_mark entitytype entitymark vectorptr tolerance param1
HyperMesh Tcl Modify Command
- ce_mark
- The mark containing the area connectors..
- entitytype
- The type of entities to map from.
- entitymark
- The mark containing the comps or elems to map from.
- vectorptr
- The direction to project.
- tolerance
- The allowable distance from the comps/elems to the area connectors.
- param1
- For future use.
Examples
To mesh area connectors 1, 2, 3 using elements 4, 5, 6, 7, 8, with allowed distance 10.0,
and projection direction (0.0, 1.0,
0.0):
*createmark connectors 1 1 2 3
*createmark elems 1 4 5 6 7 8
*createvector 1 0.0 1.0 0.0
*CE_ConnectorAreaMapMesh 1 elems 1 1 10.0 0 Meshed area connector displays as a plane with virtual elements.
