*CE_ConnectorLineCreate
Creates connector(s) on the lines at the given density or spacing.
*CE_ConnectorLineCreate entities markmask density spacing half_spacing_offset offset
HyperMesh Tcl Modify Command
- entities
- Type to specify connector location.
- markmask
- Line mark for the line collector.
- density
- Integer number to split line into number of points. Spacing between points.
- spacing
- Float number to split line into number of points with specified distance between points.
- half_spacing_offset
- Create points from an offset (= spacing/2) from the start and end of line.
- offset
- Create points from an offset (= offset) from the start and end of line.
Examples
Create a connector on line number 10 on mark 1 with a spacing of 2 and
half_spacing_offset.
*createmark lines 1 10
*CE_ConnectorLineCreate lines 1 0 2.0 1 0 Only one connector is created for each line at the center of the line and it is displayed as a cylinder.
