*CE_ConnectorSeamTrim
Trim/split seam connectors using nodes.
*CE_ConnectorSeamTrim mark_id node_mark_id tolerance snap mode
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the seam connectors to trim. Valid values are 1 and 2.
- node_mark_id
- The ID of the mark containing the trim/split nodes. Valid values are 1 and 2.
- tolerance
- The tolerance value used to snap the nodes to the point of seam connectors when snap is 1.
- snap
- 0 - Do not snap nodes to seam connectors.
- mode
- 0 - Split seam connectors.
Examples
To split seam connector 101 using node
1001:
*createmark connectors 1 101
*createmark nodes 1 1001
*CE_ConnectorSeamTrim 1 1 0.5 1 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0.110
