*CE_ConvertByMark
Converts between bolt and spot connectors.
*CE_ConvertByMark mark_id source_style target_style reserved1 reserved2
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the connectors to convert. Valid values are 1 and 2.
- source_style
- The source connector style.
- target_style
- The target connector style.
- reserved1
- Reserved for future use. Must be set to 0.
- reserved2
Examples
To convert spot connectors 101 and 102 to bolt
connectors:
*createmark connectors 1 101 102
*CE_ConvertByMark 1 "spot" "bolt" 0 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0.110
