*CE_DetailDeleteByMark
Delete connector details (stored in connector metadata) from connectors specified by mark.
*CE_DetailDeleteByMark markmask detailType detailName unknownFlag
HyperMesh Tcl Modify Command
- markmask
- Mark containing the connectors to delete details from.
- detailType
- Detail type to delete:
- detailName
- The name of the detail to delete.
- unknownFlag
- For future use (must be 0).
Examples
To delete user defined integer detail named "test" for connectors 1,
2:
*createmark connectors 1 1 2
*CE_DetailDeleteByMark 1 int "test" 0 The following commands can be used to set user-defined
details:
*CE_DetailSetUint()
*CE_DetailSetInt()
*CE_DetailSetDouble()
*CE_DetailSetString()
*CE_DetailSetTriple()
