*CE_DetailSetIntByMark
Sets an integer connector detail for a mark of connectors.
*CE_DetailSetIntByMark mark_id detail_name integer_value reserved force_storage
HyperMesh Tcl Modify Command
- mark_id
- The ID of mark containing the connectors to update. Valid values are 1 and 2.
- detail_name
- The name of the standard integer detail, or user-defined integer detail, to update. See *CE_DetailSetInt for valid details.
- integer_value
- The integer value to update for the detail.
- reserved
- Reserved for future use. Must be set to 0.
- force_storage
- 0 - Do not store user-defined detail.
Examples
To set the thickness (number of layers) to 3 for connectors 1, 2 and
3:
*createmark connectors 1 1 2 3
*CE_DetailSetIntByMark 1 ce_layers 3 0 0To set a user-defined integer detail "test" to a value of 5 for connectors 2 and
3:
*createmark connectors 1 2 3
*CE_DetailSetIntByMark 1 "test" 5 0 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
