*CE_DetailSetStringByMark
Sets a string connector detail for a mark of connectors.
*CE_DetailSetStringByMark mark_id detail_name string_value reserved force_storage
HyperMesh Tcl Modify Command
- mark_id
- The ID of mark containing the connectors to update. Valid values are 1 and 2.
- detail_name
- The name of the standard string detail, or user-defined string detail, to update. See *CE_DetailSetString for valid details.
- string_value
- The string value to update for the detail.
- reserved
- Reserved for future use. Must be set to 0.
- force_storage
- 0 - Do not store user-defined detail.
Examples
To set the user property script for connectors 1, 2, 3, and
4:
*createmark connectors 1 1 2 3 4
*CE_DetailSetStringByMark 1 ce_propertyscript "C:/temp/scripts/connectors/test.tcl" 0 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
