*CE_ExportFiles
Export connectors to their original files in their original or specified format.
*CE_ExportFiles mark_id ce_style option reserved1 reserved2 reserved3
HyperMesh Tcl Modify Command
This command exports selected connectors to their original files in original formats or specified format. The exported connectors file in XML format can be viewed either in an internet browser or in XML notepad. The ASCII or VIP format file can be viewed in any text viewer.
- mark_id
- The ID of the mark containing the connectors to export. Valid values are 1 and 2.
- ce_style
- Filter the specific type of connector to exported. Valid values are:
- all
- spot
- bolt
- apply_mass
- seam
- area
- option
- Specifies the output format:
- 0 - original format
- 1 - ASCII
- 3 - XML
- 4 - VIP
- 5 - XML 2.0
- 6 - XML 2.0 (version A)
- 7 - XML 2.0 (version B)
- reserved1
- Reserved for future use. Must be set to "".
- reserved2
- Reserved for future use. Must be set to 0.
- reserved3
Examples
To export all of the displayed connectors in XML format to their original
files:
*createmark connectors 1 "displayed"
*CE_ExportFile 1 "all" 3 "" 0 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
