*CE_ExportMainConnectorsFile
Export the connector information to a main connectors file.
*CE_ExportMainConnectorsFile mark_id filename header_string with_md
HyperMesh Tcl Modify Command
This command exports selected connectors information into a main connectors file.
- mark_id
- The ID of the mark containing the connectors to export. Valid values are 1 and 2.
- filename
- The full path and filename of the output file.
- header_string
- Optional string information to include in the header. It must start with a # or $ sign.
- with_md
- Indicates whether to write metadata information. Valid values are:
- 0 - Metadata is not written
- 1 - Metadata is written
Examples
To export all of the displayed connectors to a main connectors file named
C:/ce_info.txt, including all metadata, with a
header:
*createmark connectors 1 "displayed"
*CE_ExportMainConnectorsFile 1 "C:/ce_info.txt" "#mcf file" 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
