*CE_FE_LoadFeConfig
Load or unload an FE config file.
*CE_FE_LoadFeConfig filename load_option overwrite
HyperMesh Tcl Modify Command
This command loads or unloads an FE config file.
- filename
- The full path and filename of the FE config file.
- load_option
- 0 - to unload
- overwrite
- Valid only when load_option is 1.
- 0 - Skip FE types with names or IDs conflicting with existing ones.
- 1 - Overwrite existing FE types with names or IDs conflicting with current ones.
Examples
To load the FE config file C:/test/my_feconfig.cfg to overwrite
existing FE types with those in the
file:
*CE_FE_LoadFeConfig 1 "C:/test/my_feconfig.cfg" 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
