*CE_FE_SetSpecificDetail
Changes a single FE realization detail for connectors on the mark.
*CE_FE_SetSpecificDetail connector_mark detail_type integer_value double_value
HyperMesh Tcl Modify Command
- connector_mark
- The mark of connectors that needs to be updated.
- detail_type
- The connector FE detail to edit:
- 1 - config (integer)
- 2 - tolerance (double)
- 3 - property_id (integer)
- 4 - systems (integer: 0 or 1)
- 5 - snap_to_node (integer: 0 or 1)
- 6 - remesh (integer: 0 or 1)
- 7 - force_collinear (integer: 0 or 1)
- 8 - fe_type (integer)
- integer_value
- Pass necessary integers values through this parameter.
- double_value
- Pass necessary double values through this parameter.
Examples
*createmark connectors 1 1 2 3
*CE_FE_SetSpecificDetail 1 2 0 2.0Generally, this command is most useful to change a single previously set connector FE value. It can be used to populate all the connector’s FE values from scratch, but it is necessary that a config (or fe_type) and tolerance be properly set for realization to occur. This command makes it possible to change a single connector FE value, such as the weld config, while leaving all other FE values intact.
This command will not operate on a connector unless either the *CE_FE_SetDetails() or the *CE_FE_SetDetailsAndRealize() command has been called first on that connector (without being rejected). Before you can update a specific FE detail (*CE_FE_SetSpecificDetail), all the main FE details must be initialized (which is what the other two commands do).
