*CE_FE_SetSpecificDetailById
Changes a single FE detail for a connector specified by ID.
*CE_FE_SetSpecificDetailById ce_id detail_type int_val dbl_val
HyperMesh Tcl Modify Command
- ce_id
- The desired connector’s ID.
- detail_type
- The number of a detail:
Detail: # Range: Meaning: config 1 >0 FE configuration type of the realized connector 2 plot 3 weld 5 rigid 2 1
spring 5
5
rigidlink 6 0
bar2 6 1
rod 7
0
gap 1 0
4
quads 1 0
0
1
custom tolerance 2 >=0.0 Tolerance value for FE realization. property_ID 3 >0 FE property ID systems 4 0,1 Build system flag: 0=do not build systems
1=build systems
snap_to_node 5 0,1 FE snap to node flag 0= do not snap to node
1= snap to node
remesh 6 0,1 FE remesh flag force_collinear 7 0,1 FE force collinear flag: 0 = non-collinear
1 = collinear
fe_type 8 >0 FE type value defined in the feconfig.cfg file non_normal 9 0,1 Nonnormal projection: 0 = normal
1 = nonnormal
allow_adjacent 1 0
0,1 Allow adjacent projection: 0= don’t allow
1= allow
solver 1 1
>=0 Solver type for FE realization fevector_reverse 1 5
0,1 Vector reverse flag for seam connector trim_surf_each_side 1 6
0,1 Flag to trim surf at each side for area connectors connectivity 1 7
0,1,2 Connectivity type: 0 = independent
1 = dependent
2 = use shell node
area_thick 3 1
0,1,2,3 Area connector thickness type: 0 = (T1+T2)/2
1 = shell gap
2 = mid thickness
3 = const thickness
area_const_thick 3 2
>0.0 Constant thickness for area connectors. area_stack_size 3 3
>=0 Density for area connectors. bolt_min_dia 4 1
>=0.0 Minimum diameter for bolt hole. bolt_max_dia 4 2
>=0.0 Maximum bolt hole diameter. app_mass_mass 5 1
>=0.0 Mass for applied masses. app_mass_dis 5 2
0,1,2,3 Applied mass distribution type: 0= all nodes
1= divide by nodes
2= divide by area
3= unit area
- int_val
- The value for integer details.
- dbl_val
- The value for details with decimals.
Examples
*CE_FE_SetSpecificDetailById(3, 2, 0, 10.0)Details with decimals in the listed "range" use the dbl_val while details without them use the int_val.
