*CE_PreviewCombine
Find connectors that need to be combined and place them on the output mark.
*CE_PreviewCombine outputmark tolerance
HyperMesh Tcl Modify Command
- outputmark
- Connector mark to be populated.
- tolerance
- Search radius to find combinations.
Examples
Connectors found inside a tolerance of 0.5 will be populated on the output mark 1 if they
meet all the requirements to be combined.
*CE_PreviewCombine(1, 0.5)This command works similar to the preview empty or preview unused options in the HyperMesh Delete panel. The output mark should not contain any connectors prior to calling this command. The preview combine feature highlights all connectors that need conversion (two 2T connectors that share certain common information to a single 3T connector) within the specified tolerance.
