*CE_RemoveSigPoints
Removes significant points from a connector.
*CE_RemoveSigPoints ce_id
HyperMesh Tcl Modify Command
- ce_id
- The ID of the connector from which to remove the significant points.
Examples
To remove the significant points from connector ID
10:
*CE_RemoveSigPoints 10Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.3
