*CE_SetSpecificDetail
Sets a specific detail for all the connectors on the mark.
*CE_SetSpecificDetail ce_mark detail_type int_val dbl_val
HyperMesh Tcl Modify Command
Note: A connector must be in user control mode in order to edit the state.
Note: If the connector is in the unrealized state it can only be set to the failed
state.
Note: If the connector is in the realized, modified, failed or unconfirmed state it cannot be
set to the unrealized state.
- ce_mark
- Mark of connectors.
- detail_type
- The number for the connector detail you are editing:
- int_val
- Pass necessary integers values through this parameter.
- dbl_val
- Pass necessary double values through this parameter.
Examples
To change the thickness of the connectors on mark 1 from 2T to
3T:
*createmark connectors 1 "displayed"
*CE_SetSpecificDetail 1 1 3 0.0To change the spacing for a connector with ID 10 and 11 created at a line to
5.0:
*createmark connectors 1 10 11
*CE_SetSpecificDetail 1 101 0 5.0
