*CE_SetSpecificDetailById
Sets a specific detail for a specific connector ID.
*CE_SetSpecificDetailById ce_id detail_type int_val dbl_val
HyperMesh Tcl Modify Command
- ce_id
- A single connector ID.
- detail_type
- The number for the connector detail you are editing:
- int_val
- Pass necessary integers values through this parameter.
- dbl_val
- Pass necessary double values through this parameter.
Examples
Note: A connector must be in user control mode in order to edit the state.
To change the thickness of the connector with ID 8 from 2T to
3T:
*CE_SetSpecificDetailById 8 1 3 0.0To change the spacing for the line connector with ID 13 to
5.0:
*CE_SetSpecificDetailById 13 101 0 5.0
