*CE_UpdateCustomMessage
Attaches a custom error message to a connector.
*CE_UpdateCustomMessage id message_code
HyperMesh Tcl Modify Command
This command attaches a custom error message to a connector.
- id
- The ID of the connector to update.
- message_code
- This is the message code as specified in the Connector_Message.txt file, which is available in the HyperMesh installation directory.
Examples
The Connector_Message.txt file contains the following lines of
code-message
pairs:
11110 "Connector failed to create proper system."
11111 "Not a valid tag as link."
11112 "CE link does not have properties."To attach the first message to connector
100:
*CE_UpdateCustomMessage 100 11110Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.101
