*ME_ModuleOccurrenceDelete
Deletes a module part or part assembly, including any recursive contents.
*ME_ModuleOccurrenceDelete id ?reserved?
HyperMesh Tcl Modify Command
- id
- The ID of the module to delete. The module must be an occurrence.
- reserved
- Reserved for future use. Must be set as "".
Delete module ID 168 and all its recursive contents:
*ME_ModuleOccurrenceDelete 168
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
