*ME_ModuleOccurrenceMoveContents
Move the contents from one module part to another.
*ME_ModuleOccurrenceMoveContents source_id target_id ?"option1=value1, option2=value2, ..., optionN=valueN"?
HyperMesh Tcl Modify Command
- source_id
- The ID of the source module part whose contents are being moved.
- target_id
- The ID of the target module part receiving the contents.
- options (optional)
- List of input options, passed as a comma separated string enclosed in quotes. Valid
options are:
- purge_target=<flag>
- 0 - Keep the original destination part contents alongside the moved contents.
Delete the contents in part 40, and then move the contents of part 30 to part 40:
*ME_ModuleOccurrenceMoveContents 30 40 "purge_target=1"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
