*ME_ModuleOccurrencePurge
Empty the contents of a module part or part assembly.
*ME_ModuleOccurrencePurge id ?options?
HyperMesh Tcl Modify Command
- id
- The ID of the module to purge. The module must be an occurrence.
- options (optional)
- List of input options, passed as a comma separated string enclosed in quotes. Valid
options are:
- excluded_entity_types=type1 type2 … typeN
- A space separated list of module entity types to not remove.
- reset_representation=<flag>
- 0 - Keep representation reference information.
- recursive=<flag>
- 0 - Purge only the local module’s contents. Do not touch the child module’s contents (in the case of a part assembly).
- udm_id=<string>
- The string ID from a UDM XML file for this part, if necessary.
Purge part assembly 168 and any of its children recursively:
*ME_ModuleOccurrencePurge 168 "recursive=1"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
2017.1 - Added new options values excluded_entity_type and reset_representation.
