*ME_ModuleOccurrenceRepresentationSet2
Sets a representation of a part or a part assembly.
*ME_ModuleOccurrenceRepresentationSet2 part_id rep_key ?options?
HyperMesh Tcl Modify Command
Sets a representation of a part or a part assembly. Part occurrence should be given. Specific command will make selected representation current.
- part_id
- The ID of a part or part assembly for which to set the representation.
- rep_key
- The representation key (name).
- options
- Optional list of inputs passed as a comma separated string. Reserved for future use.
To set the representation of part ID 5 to
‘RepCAD’:
*ME_ModuleOccurrenceRepresentationSet2 5 RepCADErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
