*ME_ModulePosition
Positions a module using its hierarchical transformation matrices.
*ME_ModulePosition id position reserved
HyperMesh Tcl Modify Command
- id
- The ID of the module to position.
- position
- 0 - Transform to the normal position. This is the position the module will arrive to after applying all necessary hierarchical relative matrices.
- reserved
- Reserved for future use. Must be set to 0.
Transform module part 168 back to its original representation file position:
*ME_ModulePosition 168 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
