*ME_ModuleRepresentationAddFile2
Adds a representation file to a part or a part assembly.
*ME_ModuleRepresentationAddFile2 part_id rep_key fileformat filename ?options?
HyperMesh Tcl Modify Command
Adds a representation file to a part or a part assembly prototype. Either an occurrence or a prototype can be given.
- part_id
- The ID of a part or part assembly for which to add the representation file.
- rep_key
- The representation key (name).
- fileformat
- The representation file format (for example, JT).
- filename
- The representation file name (complete file path).
- options
- The optional list of inputs passed as a comma separated string. Reserved for future use.
To add a representation file to part ID
5:
*ME_ModuleRepresentationAddFile2 5 RepCAD JT S:/ALT13120121_003_XML71.jtErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
