*ME_ModuleRepresentationRemove2
Removes a representation from a part or a part assembly.
*ME_ModuleRepresentationRemove2 part_id rep_key ?options?
HyperMesh Tcl Modify Command
Removes a representation from a part or a part assembly. Either an occurrence or a prototype can be given.
- part_id
- The ID of a part or part assembly from which to remove the representation.
- rep_key
- The representation key (name).
- options
- Optional list of inputs passed as a comma separated string. Reserved for future use.
To remove the ‘RepCAD’ representation of part ID
5:
*ME_ModuleRepresentationRemove2 5 RepCADErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
