*ME_ModuleRepresentationRemoveFile2
Removes a representation file from a part or a part assembly.
*ME_ModuleRepresentationRemoveFile2 part_id rep_key filename ?options?
HyperMesh Tcl Modify Command
Removes a representation file from a part or a part assembly. Either an occurrence or a prototype can be given.
- part_id
- The ID of a part or a part assembly from which to remove the representation file.
- rep_key
- The representation key (name).
- filename
- The representation filename (complete file path).
- options
- Optional list of inputs passed as a comma separated string. Reserved for future use.
To remove a representation file from part ID
5:
*ME_ModuleRepresentationRemoveFile2 5 RepCAD S:/ALT13120121_003_XML71.jtErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
