*ModifySectionHandle
Modify the section shape updating the handle position. The section is identifying automatically and the handle is identified by the old position.
*ModifySectionHandle xold_coord yold_coord zold_coord xnew_coord ynew_coord znew_coord
HyperMesh Tcl Modify Command
This command updates the section shape updating the handle position.
- xold_coord
- x-coordinate of the old handle position.
- yold_coord
- y-coordinate of the old handle position.
- zold_coord
- z-coordinate of the old handle position.
- xnew_coord
- x-coordinate of the new handle position.
- ynew_coord
- y-coordinate of the new handle position.
- znew_coord
- z-coordinate of the new handle position.
To modify the section position updating the handle position:
*ModifySectionHandle 7345.06626 -1077.25964 1419.12497 7334.93373 -1077.05694 1382.59689
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
