*UpdateBinderSections
Update the binder shape using the current section. The binder and the section are identified automatically.
*UpdateBinderSections entity_type_1 mark_id_1 entity_type_2 mark_id_2 entity_type_3 mark_id_3 entity_type_4 mark_id_4 plane rotate_flag blend_flag method_flag sym_flag con_flag
HyperMesh Tcl Modify Command
This command updates the binder shape using the current section.
- entity_type_1
- Must be set to surfaces.
- mark_id_1
- Must be set to 1.
- entity_type_2
- Must be set to nodes.
- mark_id_2
- Must be set to 1.
- entity_type_3
- Must be set to lines.
- mark_id_3
- Must be set to 1.
- entity_type_3
- mark_id_3
- Must be set to 2.
- plane
- Must be set to 1.
- rotate_flag
- Must be set to 1.
- blend_flag
- Must be set to 0.
- method_flag
- Must be set to 5.
- con_flag
- Must be set to 1.
To updates the binder shape using the current section:
*UpdateBinderSections surfaces 1 nodes 1 lines 1 nodes 2 1 1 0 5 0 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
