*calculateElemDrapingAngles
Calculates the draping angles of elements associated with ply.
*calculateElemDrapingAngles mark_id result_file table_name fiber_vector stamping_vector ply_id
HyperMesh Tcl Modify Command
This command updates connectors with entities.
- mark_id
- The ID of the mark containing the ply elements. Valid values are 1 and 2.
- result_file
- Reserved for future use. Must be set to "".
- table_name
- The name of the table entity to use for storing the results.
- fiber_vector_id
- The ID of the vector defining the fiber direction, defined using the *createvector command.
- stamping_vector_id
- The ID of the vector defining the stamping direction, defined using the *createvector command.
- ply_id
- The ID of the ply.
Examples
To calculate the draping angle of elements associated with ply 10 having fiber direction
(1,0,0) and stamping direction
(0,1,0):
*createmark elements 1 "by ply id" 10
*createvector 1 1 0 0
*createvector 2 0 1 0
*calculateElemDrapingAngles 1 "" drapetable 1 2 10Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
