*hf_ClearLLHandles
Delete all the handles from the model.
*hf_ClearLLHandles int_flag
HyperMesh Tcl Modify Command
This command deletes all the handles and the handles node pointer from the model.
- int_flag
- Integer dummy value. Should always be set to 0.
To delete the handles:
*hf_ClearLLHandles 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
