*hf_CreatePol
Creates POL from the current trim line, with the specified offset.
*hf_CreatePol offset
HyperMesh Tcl Modify Command
This command creates POL from the current trim line, with the specified offset.
- offset
- The offset specified for the POL.
To create POL from the current trim line with offset of
100:
*hf_CreatePol 100Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
