*hf_Create_DieCadSys
Creates a system from the CAD system stored in the database.
*hf_Create_DieCadSys reserved
HyperMesh Tcl Modify Command
This command creates a system from the CAD system stored in the database.
- reserved
- Reserved for future use. Must be set to 0.
To create a system from the CAD system stored in the
database:
*hf_Create_DieCadSys 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
